TwinTurbo.NET: Nissan 300ZX forum - Re: Re: Sounds like the injector or injector connection.
Subject Re: Re: Sounds like the injector or injector connection.
Posted by Zuberman on April 23, 2015 at 9:28 AM
  This message has been viewed 332 times.
In Reply To Re: Sounds like the injector or injector connection. posted by anthony90_z32 on April 22, 2015 at 10:59 PM
Message Get some QD Electronics Cleaner, which is safe for plastic. After you spray the cleaner in the contacts, connect then dis-connect several times so that the contacts scrub each other and better clean off any corrosion.
RISKY: you might also try giving the male spade a TINY CAREFUL twist. Using a medical hemostat works great for this due to clearance.
You still need to check that the wiring that joins directly to the injector-connector is solid. It's integrity could be compromised.
