TwinTurbo.NET: Nissan 300ZX forum - Maybe ECU & Harness?
Subject Maybe ECU & Harness?
Posted by ChristopherTheOne on April 23, 2015 at 2:24 AM
  This message has been viewed 327 times.
In Reply To '96NA Engine on a '93NA ECU, Off Idle Stumble posted by Cjw3 on April 21, 2015 at 08:34 PM
Message Injectors are the same, and the TPS should be as well.
My suspicion would be to look at the ECU.
You probably already know the '96MY USA engines were slightly different animals due to the OBD-II requirements. I've read that you can control them with an earlier MY ECU, but they'll run rich and tend to fail inspections.
You might want to look at getting a '96 ECU program for it (assuming you aren't already using one).
