TwinTurbo.NET: Nissan 300ZX forum - Re: What do you mean by the connector doesn't work?
anthony90_z32
on April 22, 2015 at 10:57 PM
posted by ttsmokin
on April 22, 2015 at 01:35 PM
I mean it has no voltage. It looks clean so corrosion shouldn't be a issue. I tested the connector on a cylinder that I know works and it had no spark
help, have problems with injector and coil packs
anthony90_z32
22:10:56 04/21/15
Make the pins on the conectors are clean, like
Red Hawk (CO)
12:01:50 04/22/15
Re: Make the pins on the conectors are clean, like
slcZ32
13:38:21 04/22/15
anthony90_z32
22:53:49 04/22/15
ttsmokin
13:35:18 04/22/15
Re: What do you mean by the connector doesn't work? -
anthony90_z32
22:57:11 04/22/15
Your PTU connectors are probably corroded then.
ttsmokin
17:27:19 04/23/15
Re: Your PTU connectors are probably corroded then.
anthony90_z32
19:51:05 04/23/15
Sounds like the injector or injector connection.
Zuberman
14:06:19 04/22/15
Re: Sounds like the injector or injector connection.
anthony90_z32
22:59:54 04/22/15
Needle files work well
ChristopherTheOne
01:39:59 04/23/15
Re: Re: Sounds like the injector or injector connection.
Zuberman
09:28:58 04/23/15
