TwinTurbo.NET: Nissan 300ZX forum - I agree w/Nate, plus...
Subject I agree w/Nate, plus...
Posted by ChristopherTheOne on April 19, 2015 at 2:50 PM
  This message has been viewed 271 times.
In Reply To z stubbling under half throttle - heavy throttle around 2500 posted by jhop1988 on April 16, 2015 at 08:42 PM
Message ...in particular, check for corrosion in the TPS and CAS connectors. If those look good, you might check the injector connectors (also check their electrical impedance while you have the leads exposed -- should be 10-14 Ohms for each one).
One reason to fill out your profile is so we know if you're running an NA or turbo engine. Often, stumbling performance can be related to boost/vacuum leaks, so that's always a good thing to inspect for.
