TwinTurbo.NET: Nissan 300ZX forum - Re: Update: Harness problem.
Rasta420
on April 16, 2015 at 10:43 AM
posted by TyTyIsFly27
on April 16, 2015 at 10:33 AM
the wire you tapped into, is it in the driver wheel well? if it is then you bypassed the relay and that would make the relay suspect, not the harness. This is assuming yours in an automatic and other assumptions also
91 2+2 NA Auto
90 2+0 TT, 5spd
Car won't crank. Starter and solenoid are good. What gives?
TyTyIsFly27
09:52:08 04/16/15
TyTyIsFly27
10:33:58 04/16/15
Re: Update: Harness problem. -
Rasta420
10:43:45 04/16/15
I tapped into the B/Y AFTER the relay. Problem solved.
TyTyIsFly27
14:46:52 04/16/15
