TwinTurbo.NET: Nissan 300ZX forum - The Z pretty much needs to be running preem
Subject The Z pretty much needs to be running preem
Posted by BlackholeZ on April 14, 2015 at 10:41 PM
  This message has been viewed 300 times.
In Reply To 555 injectors and Z1 chip, can't pass emission test posted by AL on April 13, 2015 at 08:27 PM
Message It's easy to pass with quite a bit of mods, as long as it's running well. How old are your O2 sensors? Is your TPS properly adjusted? Is it idling at the correct RPM? Coolant sensor connectors clean? Coolant full? Go through the 6 Ps.
Also how hot were your cats? I failed my first time because it had sit for 15 minutes not running. Second time I pulled up and put it on the roller immediately and passed flying colors.
-Dan
VTC Solenoid Caps and install instructions.
"Capitalization is the difference between helping your Uncle Jack off a horse, and helping your uncle jack off a horse."
"'she' also likes to swap since I think I am going to need to give her to woody again." - Dvlhntr
"full alphabetic boost mode" - ChristopherTheOne
" Purrs like a sexually satisfied black panther." - BigTDogg
"Two oil eating, angry, spinning triangles of death." - turtleboy on rotary engines
