TwinTurbo.NET: Nissan 300ZX forum - Rust will go away with a few minutes of running
Subject Rust will go away with a few minutes of running
Posted by Cjw3 on April 13, 2015 at 9:38 PM
  This message has been viewed 301 times.
In Reply To Re: Rust on the seats will likely be a factor. posted by Matt300ZXT on April 13, 2015 at 05:38 PM
Message Like I said.. Tap the Valve Stem to 'Pop' the valve on the seat to see if you can nock some of the rust off.. spray a lite oil in there ( WD-40 type ) and see if the numbers improve..
If they come up to the less than 20% range, then good.. Else you might want to pull it..
It's all a gamble ..
Cj
