TwinTurbo.NET: Nissan 300ZX forum - Differential is now off car. I'll hold the half shaft
Subject Differential is now off car. I'll hold the half shaft
Posted by flashstar on April 13, 2015 at 2:21 PM
  This message has been viewed 425 times.
In Reply To Try this. Lock the tranny on gear rise both rears off the >> posted by ZUL8TR on April 13, 2015 at 01:48 PM
Message have my brother rotate each wheel, and get back to you. It looks like the differential has more backlash than the half shafts though. A bit more than 1/8" at each differential output shaft when rotating the shafts separately.
It sounds like you're on the same track though. I suspected that my automatic took up the slack in drive so much that I never noticed.
Do you think a rebuilt half shaft will have less play? I could pick one up at O'Reilly's and compare. I'm planning to pull my sub-frame to have the bushings replaced anyway. I could have the machine shop swap the half shafts.
