TwinTurbo.NET: Nissan 300ZX forum - Axial play sounds worse on outers. Inners have more radial
Subject Axial play sounds worse on outers. Inners have more radial
Posted by flashstar on April 13, 2015 at 1:28 PM
  This message has been viewed 410 times.
In Reply To check the outer axel joint it is usually worse, post results (n/m) posted by ZUL8TR on April 13, 2015 at 01:13 PM
Message play. I just don't know what amount of backlash and play are in a "good" half shaft. I've heard these half shafts are designed to have a certain amount of axial play, although I could be wrong.
Each outer joint has around 7-8mm of axial play. Very little radial play.
Each inner joint has some axial play but noticeable radial play. When rotating the inner joints, I can hear a faint knocking sound.
I'm wondering if all of my components could have a small amount of backlash that is adding up and causing a clunk?
