TwinTurbo.NET: Nissan 300ZX forum - Recessed Square Drive. Long breaker bar stripped out the
Subject Recessed Square Drive. Long breaker bar stripped out the
Posted by flashstar on April 12, 2015 at 1:11 AM
  This message has been viewed 387 times.
In Reply To Does your drain-plug have a head on it? Or is it a recessed posted by Zuberman on April 12, 2015 at 12:58 AM
Message slot. I may be able to get about 50-60 ft lbs on the plug to break the seal if I heat up the cover though. Otherwise, I could see about welding a nut to the plug...
I'd get a Greddy cover but not sure if it's worth $400.
I'll check my half shafts once I remove the differential but I believe most play is coming from within the differential.
