TwinTurbo.NET: Nissan 300ZX forum - Does your drain-plug have a head on it? Or is it a recessed
Zuberman
on April 12, 2015 at 12:58 AM
Differential Backlash, Clunk-> Replace or Shim?
posted by flashstar
on April 12, 2015 at 12:04 AM
square drive?
flashstar
00:04:19 04/12/15
Does your drain-plug have a head on it? Or is it a recessed -
Zuberman
00:58:46 04/12/15
Recessed Square Drive. Long breaker bar stripped out the
flashstar
01:11:10 04/12/15
Can you post a close-up pic of the drain-plug?
Zuberman
02:10:52 04/12/15
Here's a picture!
flashstar
21:26:25 04/12/15
Try bolt out extractor
Ron(Houston)
22:16:26 04/12/15
WHEW! That's pretty bad. Here's what I had in mind....
Zuberman
13:00:01 04/13/15
Thanks! I'll try this on the old differential when I finish
flashstar
13:30:22 04/13/15
It's not my original idea. Others used electrical tape, so I
Zuberman
13:47:11 04/13/15
I would use 1/8 thick flat steel cut to make a jamb fit >>
ZUL8TR
13:31:07 04/13/15
It turns out that some backlash was coming from my axles
flashstar
21:30:52 04/12/15
check the outer axel joint it is usually worse, post results (n/m)
ZUL8TR
13:13:27 04/13/15
Axial play sounds worse on outers. Inners have more radial
flashstar
13:28:44 04/13/15
Try this. Lock the tranny on gear rise both rears off the >>
ZUL8TR
13:48:17 04/13/15
Differential is now off car. I'll hold the half shaft
flashstar
14:21:39 04/13/15
A good comparison would be to check with a 1/2 shaft that >>
ZUL8TR
04:07:13 04/14/15
The O'Reilly's is a reman, although it's a MasterPro...
flashstar
12:15:17 04/14/15
The O'Reilly shafts have just as much play in them
flashstar
12:54:28 04/15/15
that eliminates one item from the search, keep us posted. (n/m)
ZUL8TR
04:18:49 04/16/15
Re: It turns out that some backlash was coming from my axles
slcZ32
12:46:47 04/14/15
