TwinTurbo.NET: Nissan 300ZX forum - It should be activating based on the RPM
Subject It should be activating based on the RPM
Posted by zromtech on April 10, 2015 at 12:27 PM
  This message has been viewed 328 times.
In Reply To Question on VTC activation points. posted by xpwarrior on April 09, 2015 at 10:58 AM
Message The ECU checks the RPM activation points before the TP. The ECU won't turn on VTC if either the neutral or idle switch are engaged, so check to make sure you don't have an issue with those.
The logic that controls VTC happens in a specific order:
if (neutral or idle) turn off VTC
else if (coolant temp < min VTC temp) turn off VTC
else if (coolant temp > max VTC temp) turn off VTC
else if (vehicle speed < min VTC speed) turn off VTC
else if (RPM > max VTC RPM) turn off VTC
else if (RPM > min VTC RPM) turn on VTC
else if (TP > min VTC TP) turn on VTC
