TwinTurbo.NET: Nissan 300ZX forum - I see exactly what you're doing wrong here.
Subject I see exactly what you're doing wrong here.
Posted by Goldchocobo on April 09, 2015 at 4:19 PM
  This message has been viewed 346 times.
In Reply To No, after it is bolted down and the belt is around the posted by Tanley on April 09, 2015 at 04:17 PM
Message You need to compress the tensioner down to around 2mm-1mm BEFORE installing the belt in order to get the tensioner orientated right. If you're trying to install it while it's set to 4mm, you never get enough tension once the stopper bolt is released.
