TwinTurbo.NET: Nissan 300ZX forum - Hold up...
Hold up...
Goldchocobo
on April 09, 2015 at 4:07 PM
I think I wrote that wrong, it was 4mm out of the box with
posted by Tanley
on April 09, 2015 at 04:41 AM
Are you leaving the stopper bolt IN the tensioner after installing it?
Tight timing belt tensioner.
Tanley
21:39:48 04/08/15
Re: Tight timing belt tensioner.
Goldchocobo
22:31:11 04/08/15
Tanley
04:41:53 04/09/15
Hold up... -
Goldchocobo
16:07:30 04/09/15
No, after it is bolted down and the belt is around the
Tanley
16:17:12 04/09/15
I see exactly what you're doing wrong here.
Goldchocobo
16:19:11 04/09/15
Interesting, the FSM states to adjust the tensioner to the
Tanley
16:55:44 04/09/15
Sorry, I was under a misunderstanding.
Goldchocobo
17:43:21 04/09/15
tumevain
10:02:48 04/09/15
Yep, tried that multiple times, no change. (n/m)
Tanley
12:20:28 04/09/15
There is a small amount of play in the bolt
xpwarrior
18:15:05 04/09/15
Hmm I did not know that, I'll loosen it up and retighten
Tanley
19:49:20 04/09/15
So I finally got it to 3.5 mm
Tanley
19:50:16 04/10/15
Which manufacturer made the OEM belt you are using?
xpwarrior
21:44:44 04/10/15
It's a Unitta belt. I was thinking about doing that, but
Tanley
22:52:51 04/10/15
