TwinTurbo.NET: Nissan 300ZX forum - I'm not Turbo Orented.. So I wont answer Yes or No
Subject I'm not Turbo Orented.. So I wont answer Yes or No
Posted by Cjw3 on April 07, 2015 at 3:10 PM
  This message has been viewed 319 times.
In Reply To Re: Sounds like a Throttle Enrichment problem posted by Dragginz on April 07, 2015 at 02:29 PM
Message But when ever a change is made to the 'System' it needs to be reflected in the tune..
I would not think that charge pipes would cause what you are seeing.. I would expect it to be an Injector Difference..
But I do not know all the Interactions of the 'On to Idle Transitions' that happen in the Turbo System..
But you have new Piping.. that should make the System breath better.. I'd at least get the Tune Fixed to reflect your new stuff..
The Tuner might have some insights into your issue..
Do you have Two Widebands?..
Cj
