TwinTurbo.NET: Nissan 300ZX forum - Sounds like a Throttle Enrichment problem
Subject Sounds like a Throttle Enrichment problem
Posted by Cjw3 on April 07, 2015 at 1:17 PM
  This message has been viewed 331 times.
In Reply To Dies After Revving (I've tried everything!) posted by Dragginz on April 07, 2015 at 11:16 AM
Message You said the Mixtures go rich.. I'd look there..
What Tune/Prom are you running..
I was doing some NA Prom work on my NA '90.. similar symptoms.. End up it was self inflicted..
I had increased the K Value and Injector Latency trying to Stabilize an Idle SMOG issue, but ended up making it Stumble if the throttle was opened, then closed quickly.. When I was Feathering it during clutch engagement.. Light weight Flywheel on this NA..
Presently I have not found the Throttle enrichment table.. so I put my Values back and that problem went away..
The Org problem was I was trying to get the ECU to Idle at Stoch.. with an O2 Sensor Hunt.. It really does not like to do that.. At least in a 'Stable' Oscillation..
I will approach that problem in a different way..
Cj
