TwinTurbo.NET: Nissan 300ZX forum - kinugawa wastegate - engine mount clearance
Subject kinugawa wastegate - engine mount clearance
Posted by irdhp on April 07, 2015 at 10:01 AM
  This message has been viewed 311 times.
Message Replacing the the garret wastegate with kinugawa that I can change spring rate on. I have a problem with clearance on the right side. The wastegate is a bit to high/long. It bumbs into the engine mount. I need about 1cm in order to get the turbo on again.
Is it possible to cut out a piece in order to get clearance enough? Will it still be safe to drive like that?
