TwinTurbo.NET: Nissan 300ZX forum - Can you hear the fuel pump running when the key
Tanley
on March 29, 2015 at 2:31 PM
300zx help!
posted by Irishguy73
on March 29, 2015 at 01:05 PM
is in the on position, before you start it?
300zx help!
Irishguy73
13:05:59 03/29/15
Can you hear the fuel pump running when the key -
Tanley
14:31:57 03/29/15
Re: 300zx help!
caliz32
15:20:24 03/29/15
Run the ECU diagnostics as a first step. (n/m)
spicyZ
11:54:54 03/30/15
37K original miles: car has sat a lot. Is this the first
Zuberman
23:51:09 03/31/15
Re: 37K original miles: car has sat a lot. Is this the first
Irishguy73
22:36:13 04/01/15
Have you run the ECU diagnostics as I suggested?
spicyZ
10:28:25 04/02/15
Re: Have you run the ECU diagnostics as I suggested?
Irishguy73
16:06:15 04/02/15
This might help....
Zuberman
14:30:24 04/04/15
Re: This might help....
Irishguy73
00:30:47 04/06/15
That is about the same routine the mechanic will use to
Zuberman
09:08:32 04/06/15
I would recommend against relocation
spicyZ
12:04:36 04/06/15
This is textbook behavior for a failing PTU
spicyZ
12:02:56 04/06/15
Re: This is textbook behavior for a failing PTU
Irishguy73
20:11:42 04/06/15
