TwinTurbo.NET: Nissan 300ZX forum - Unless you're positive the surfaces are fine, I would have
Subject Unless you're positive the surfaces are fine, I would have
Posted by Zuberman on March 29, 2015 at 1:05 PM
  This message has been viewed 232 times.
In Reply To Re: Probably needs to be honed. Did you check for pitting or any posted by slcZ32 on March 29, 2015 at 03:08 AM
Message it professionally inspected and/or honed by a brake-specific shop. If you feel you can do the work reliably, then here is a good beginner's start......
https://books.google.com/books?id=H922It35HOMC&pg=PA97&lpg=PA97&dq=brake+master+cylinder+hone+procedure&source=bl&ots=bUZCSTYtgD&sig=reHfd3xQ5RHblTtH7aHKmGSdnWM&hl=en&sa=X&ei=3jsYVYGQCoqkgwT2hgM&ved=0CEQQ6AEwBg#v=onepage&q=brake%20master%20cylinder%20hone%20procedure&f=false
and here is some good stuff....
[ http://www.twinturbo.net/nissan/300zx/forums/technical/view/777808/Re-All-righty-now.html ]
Strictly speaking for myself, I would have bought a replacement unit. Re-building stuff like that can have some issues since a re-manufacturing plant has some very expensive equipment set up to make stuff with tight tolerances, or even a new part manufacturing plant which also has some very expensive finely engineered machines that we don't have at home; example, the micro-honing process for new engine blocks.
