TwinTurbo.NET: Nissan 300ZX forum - If the oil was heavy enough to coat the plug and
Tanley
on March 28, 2015 at 7:11 PM
Car smokes very faintly while warm. (n/m)
posted by LivinTheDream
on March 28, 2015 at 02:17 PM
foul it then yes it could affect the AFR, but if the oil is not fouling the plug I would think that it wouldn't be enough to affect the AFR very much. I am assuming you are seeing blue oil smoke when it's warmed up?
Do you think leaky valve seals would cause a rich afr?
LivinTheDream
08:18:35 03/28/15
Have you pulled the plugs and taken a look at them?
Tanley
10:40:09 03/28/15
I know for sure that I have oil in the cylinder chamber....
LivinTheDream
14:16:57 03/28/15
I'm sure you are going to do it anyway, but...
Goldchocobo
19:43:52 03/28/15
all valve seals and cam seals are being replaced in car (n/m)
LivinTheDream
20:18:45 03/28/15
Good man. (n/m)
Goldchocobo
00:39:47 03/29/15
LivinTheDream
14:17:21 03/28/15
If the oil was heavy enough to coat the plug and -
Tanley
19:11:03 03/28/15
its so faint but I assume white smoke. full synthetic (n/m)
LivinTheDream
20:16:11 03/28/15
foul to the point of causing a miss is what u mean?
LivinTheDream
20:17:24 03/28/15
