TwinTurbo.NET: Nissan 300ZX forum - I’ve pulled a pan in place and pulled a dent w/ welder >>
Subject I’ve pulled a pan in place and pulled a dent w/ welder >>
Posted by my91z on March 28, 2015 at 2:40 PM
  This message has been viewed 283 times.
In Reply To low oil pressure dented oil pan posted by jhop1988 on March 28, 2015 at 12:02 PM
Message I pulled the pan when I was still NA to replace rod bearings by supporting the engine with a 4x4 and slings and using a jack stand on the crank pulley and jack under the trans as insurance.
After I did my TT swap I had an oil pressure issue. I had my friend come over and weld an allthread rod (about 12-18 inches long as I recall) to the pan at the dent.
The rod had a 1/4” or 3/8” plate about the size of a playing card welded to the other end and I used a 3 lb sledge to knock it down. Then cut off the rod close to the pan, re-weld the rod, knock downward, cut, re-weld, etc. Got the dent out and solved the oil pressure issue.
I’d say the weld and hammer method was FAR easier than pulling the pan.
Mike
SRC="http://images.honesty.com/imagedata/h/402/36/24023634.j
pg" BORDER=0>
SRC="http://img718.imageshack.us/img718/4913/99m3ttnetsigpic
9564.jpg" BORDER=0>SRC="http://images.honesty.com/imagedata/h/365/13/23651377.g
if" ALT="Click here to e-mail me!" BORDER=0>
