TwinTurbo.NET: Nissan 300ZX forum - I know for sure that I have oil in the cylinder chamber....
Subject I know for sure that I have oil in the cylinder chamber....
Posted by LivinTheDream on March 28, 2015 at 2:16 PM
  This message has been viewed 275 times.
In Reply To Have you pulled the plugs and taken a look at them? posted by Tanley on March 28, 2015 at 10:40 AM
Message and on plugs. When I remove plugs a few of them will have oil on the plug threads and even on the plugs washer. Its not horrible but things are wet. I had the engine out and know that both exhaust and intake valves are leaking slightly. They were wet anyway. My compression is good and Im in the process of doing a leak down test. My engine is already pulled down, minus cams, to change the valve seals. Laziness i why i didnt do it while the engine was out. I thought no big deal at the time.
"torque gets you off the line...& hp gets you over the line." -
TTKeeper
