TwinTurbo.NET: Nissan 300ZX forum - tighten the bolts enough to seat the girdle in the block
Subject tighten the bolts enough to seat the girdle in the block
Posted by aliaZ on March 28, 2015 at 1:11 PM
  This message has been viewed 256 times.
In Reply To Axial shifting of crank shaft to set bearing caps. posted by Tanley on March 28, 2015 at 11:30 AM
Message and then back off the bolt torque. Tap the crank with a plastic hammer at the flywheel end to move it forward. This will shift the girdle a bit in the block so that the thrust surfaces on the upper and lower bearing shells are aligned. the crank should spin freely. If it doesn't, the #4 crank bearing isn't aligned top to bottom, and binds up your crank.
Check to see that your crank end play is in spec with a dial indicator if you have one.
