TwinTurbo.NET: Nissan 300ZX forum - PS pump O-ring replacement??? OEM must??
Subject PS pump O-ring replacement??? OEM must??
Posted by LivinTheDream on March 27, 2015 at 11:47 PM
  This message has been viewed 265 times.
Message Guys Im curious if the o-ring that goes under the ps pumps feed tube (that the supply hose from the res attaches to) must be OEM or I can just match it up with any rubber O-ring. Thanks
Also the front alternator bearing (closest to pulley) is discontinued as a nissan part and I was curious where to source it? The 89-93, late 93's, and 94-96 all seem to to take different bearings according to courtesy parts.
"torque gets you off the line...& hp gets you over the line." -
TTKeeper
