TwinTurbo.NET: Nissan 300ZX forum - Supplies power 2 eccs, ign relay, injectors, ecu memory
Subject Supplies power 2 eccs, ign relay, injectors, ecu memory
Posted by LivinTheDream on March 27, 2015 at 8:59 PM
  This message has been viewed 269 times.
In Reply To Fuel fusible link has 2 voltages posted by vice on March 26, 2015 at 06:59 PM
Message At least in regards to the engine. Disconnect the ecu and test again and see if u still get volts on the other contact. This fuse should share continuity with one of the contacts of the fuse next to it. Unplug them both and check for continuity to confirm. They share the same supply feed. But the ecu grounds out the eccs and ignition relay to send power to those systems through means of an orange colored ground wire. If I'm correct that is. Just how you have to wait for power drain on some devices (10sec -10min) thus could be likewise.
"torque gets you off the line...& hp gets you over the line." -
TTKeeper
