TwinTurbo.NET: Nissan 300ZX forum - Pressure tested the coolant system. Holds perfect.
Subject Pressure tested the coolant system. Holds perfect.
Posted by LivinTheDream on March 26, 2015 at 9:20 PM
  This message has been viewed 229 times.
In Reply To MYSTERY Liquid atop my valves.. any ideas????? posted by LivinTheDream on March 25, 2015 at 10:43 PM
Message So I did two pressure test of the coolant system. One at 10psi and another at 12psi, according to my gauge. I waited 10min during the first test and 20 minutes on the second at 12psi. The results for both test was zero loss of pressure.
As for the leak down test, would it not be easier to do that with the cam shafts removed and all of the valves closed a opposed to finding tdc on the compression stroke of each?
What is the best way to find tdc on the compression stroke?
"torque gets you off the line...& hp gets you over the line." -
TTKeeper
