TwinTurbo.NET: Nissan 300ZX forum - I have confirmed most questions. The Z32TT bearing
Subject I have confirmed most questions. The Z32TT bearing
Posted by joshd on March 21, 2015 at 10:20 PM
  This message has been viewed 378 times.
In Reply To That sounds like one of those, "We have to pass the bill so posted by Zuberman on March 21, 2015 at 02:45 PM
Message will bolt onto the Z32 NA knucle. To make this swap work i will need to use Z32TT bearings as the Q45 bearing doesnt have provisions for the inner parking break as the Q45 uses a parking break caliper Instead. The 90-96 Q45 axles are identical however still need to verify if the Q45 and Z32TT output shafts are the same length.
So. 90-96 Q45 R200 with 30spline 6 bolt output shafts with 6bolt Q45 or Z32TT 6bolt axles in to my Z32 NA knuckles with Z32TT bearings installed.
This would produce a R200 differential with Z32TT R230 strength all the way out to the wheels without needing to swap a subframe and run hicas elimination.
All that is left is to identify the length of the 90-96 Q45 R200 output shafts and start swapping.
