TwinTurbo.NET: Nissan 300ZX forum - Re: If you have a bad heater core losing system
Subject Re: If you have a bad heater core losing system
Posted by L£AÐZX on March 18, 2015 at 2:20 AM
  This message has been viewed 242 times.
In Reply To If you have a bad heater core losing system posted by ttz'in (norcal) on March 18, 2015 at 01:54 AM
Message The only reason I wanted to bypass the heater core is to prevent leakage into the cabin and would be easier than replacing the core itself. If that is the cause of my low coolant level then that should fix my over heating problem as well. I did use distilled water btw just to top of the mixture because it was low.
