TwinTurbo.NET: Nissan 300ZX forum - Re: Well ... I'll just go with the 100mm.
ttz'in (norcal)
on March 18, 2015 at 1:57 AM
posted by nonstopna
on March 18, 2015 at 01:54 AM
Well... I'll just...Doesn't make it with these cars.
Figure out correct bolt.
At the least fit a pipe cleaner or equivalent in the hole and measure it.
Relicating knock sensor... M8-1.25 x 90mm Correct size ?
nonstopna
00:07:28 03/18/15
Use the 100mm....
Zuberman
00:44:21 03/18/15
Unless you want to do the math of subtracting the nut in
Zuberman
00:50:29 03/18/15
nonstopna
01:54:14 03/18/15
Re: Well ... I'll just go with the 100mm. -
ttz'in (norcal)
01:57:23 03/18/15
Goldchocobo
12:48:24 03/18/15
2nd. I used my inch-lbs torque wrench to make sure I didn't
Zuberman
13:01:23 03/18/15
Re: Relicating knock sensor... M8-1.25 x 90mm Correct size ?
nonstopna
16:38:35 03/18/15
Sounds good.. (n/m)
ttz'in (norcal)
20:19:39 03/18/15
