TwinTurbo.NET: Nissan 300ZX forum - Re: Re: Wet driver side carpet
Subject Re: Re: Wet driver side carpet
Posted by L£AÐZX on March 17, 2015 at 11:49 PM
  This message has been viewed 245 times.
In Reply To Re: Wet driver side carpet posted by Zuberman on March 17, 2015 at 10:42 PM
Message Thanks for the advice everyone. Ill have to check my a/c condensation tube, fan clutch, and thermostat tomorrow. I wasnt aware you had to do a plenum pull for the heater bypass so ill hold off on that for now..
I recently flushed my radiator when I did my powersteering pump and I did use only 50/50 at first but have been topping it off with lots of water when it gets low, still got too hot with only 50/50 tho. Ran perfectly fine during winter but then the weather got warmer and I started using the a/c again.
I added water wetter today and replaced this cheapo 13lb radiator cap that came on the car with a new 19lb Z1 cap. It seemed to help a bit but im still seeing 200-210 water temps on longer drives or in heavy traffic
