TwinTurbo.NET: Nissan 300ZX forum - Had it pulled out yesterday and welded up the crack along
rcmadness
on March 17, 2015 at 10:54 AM
A-HA! So it is the bracket! Diagnosis is always the worst
posted by Zuberman
on March 12, 2015 at 11:02 PM
with some reinforcement. Feels good again. This thing must have an aftermarket clutch in it because the spring is super stiff, stiffer than any other I've drove which is probably a contributing factor for the pedal bracket failure.
Firewall flexing at clutch master cylinder
rcmadness
10:54:29 02/28/15
Is the top bolt in place that holds the bracket ? (n/m)
11:22:14 02/28/15
I can see the bolt head is there but is there a nut on the
rcmadness
12:12:08 02/28/15
Trapped nut. (n/m)
19:21:30 02/28/15
Re: Firewall flexing at clutch master cylinder
Konigg
12:13:03 02/28/15
In the 4th photo down in that article you will see the
rcmadness
12:31:18 02/28/15
Re: In the 4th photo down in that article you will see the
Konigg
16:22:12 02/28/15
Konigg
12:15:20 02/28/15
I know how to adjust the clutch and the switch is all the
rcmadness
12:24:38 02/28/15
I would imagine you would have noticed by now, but is the
davidztt
16:59:19 02/28/15
Found it...
rcmadness
17:44:40 03/11/15
Zuberman
23:02:05 03/12/15
Had it pulled out yesterday and welded up the crack along -
rcmadness
10:54:43 03/17/15
