TwinTurbo.NET: Nissan 300ZX forum - It's a pain
Subject It's a pain
Posted by BlackholeZ on March 16, 2015 at 10:21 PM
  This message has been viewed 333 times.
In Reply To I'm stuck. Please help. How do I get the first set of posted by Zuberman on March 16, 2015 at 11:13 AM
Message I actually had to give up on the last set that I tried to pull. Really the best time to do downpipes is when the trans is out or the plenum is off. With the trans out you can rock the motor forward to give more clearance to the firewall. With the plenum off you have better access to the top of it and don't have to do everything from the bottom. I pull the shields off the brake and fuel lines when doing the driver's side. TBH it's probably worth pulling the trans. It's not actually that hard and can give you a good bit more space.
The scary thing is when one of the bolts starts feeling like it's starting to bind.
-Dan
VTC Solenoid Caps and install instructions.
"Capitalization is the difference between helping your Uncle Jack off a horse, and helping your uncle jack off a horse."
"'she' also likes to swap since I think I am going to need to give her to woody again." - Dvlhntr
"full alphabetic boost mode" - ChristopherTheOne
" Purrs like a sexually satisfied black panther." - BigTDogg
"Two oil eating, angry, spinning triangles of death." - turtleboy on rotary engines
