TwinTurbo.NET: Nissan 300ZX forum - Re: idle and drive issues.
Subject Re: idle and drive issues.
Posted by Goldchocobo on March 16, 2015 at 3:39 PM
  This message has been viewed 233 times.
In Reply To idle and drive issues. posted by Mizzuh on March 16, 2015 at 03:08 PM
Message Definitely an air leak somewhere. Did you cap the holes you created in the EGR delete?
Also, check plenum torque amounts. They should be 12-15lbs. I do 13lbs, to be safe.
Do an entire go over of every vacuum line. Try spraying starter fluid around your plenum gasket area - the rpm will change as you do so, indicating a leak. You can also try using a piece of vacuum line as a stethoscope while searching for any air leaks.
