TwinTurbo.NET: Nissan 300ZX forum - Either bad rings or valves leaking. Do a leak down >>
Subject Either bad rings or valves leaking. Do a leak down >>
Posted by ZUL8TR on March 15, 2015 at 5:33 AM
  This message has been viewed 245 times.
In Reply To Looking for feedback on low compression numbers. posted by J-Mart on March 14, 2015 at 09:47 PM
Message test on #6. I would also test #6 valve sealing at TDC of compression stroke so all the valves there are closed then pressure up that cylinder and listen at the intake for backflow thru the intake plenum. This test usually done with smoke injection and see it out the intake.
Perform these tests before any pull apart because that is the real work.
ZUL8TR in Orlando,FL
