TwinTurbo.NET: Nissan 300ZX forum - Cylinder #6 was tested twice in each condition.
Subject Cylinder #6 was tested twice in each condition.
Posted by J-Mart on March 14, 2015 at 11:04 PM
  This message has been viewed 227 times.
In Reply To How many times did you check the #6 cylinder? posted by SammybTT(TN) on March 14, 2015 at 10:40 PM
Message It was tested dry twice, the second time after removing the adapter and lubing the o-ring on the adapter. I had a similar experience to what you are describing previously.
After the test returned the same results, I added oil to the cylinder and repeated. I did not remove the tester though this time, and l just cranked it over again after venting the first tests pressure.
Jared
1994 Twin Turbo
