TwinTurbo.NET: Nissan 300ZX forum - A bit of info regarding the WOT switch.
Subject A bit of info regarding the WOT switch.
Posted by DVDBURN (MD) on March 14, 2015 at 7:00 AM
  This message has been viewed 397 times.
In Reply To Some info on the operation of the TPS. posted by DVDBURN (MD) on March 11, 2015 at 11:20 PM
Message In a Z with automatic transmissions the WOT switch is used for forcing a downshift into the lowest possible gear ratio if the throttle pedal is fully depressed. This is referred to as "throttle kickdown" and is in response to an abrupt increase in engine power. As an example, lets say you are driving at 55 mph and you have your automatic overdrive switch engaged. You then floor the throttle which engages the WOT switch. The switch tells the A/T control unit to change into the lowest possible gear ratio taking it out of overdrive mode.
www.mytwinturbo.com
Nissan Data Voice on YouTube
