TwinTurbo.NET: Nissan 300ZX forum - Re: Timing Belt Change...What Upgrades/Maintenance Same Time
Subject Re: Timing Belt Change...What Upgrades/Maintenance Same Time
Posted by Antihero on March 13, 2015 at 9:23 AM
  This message has been viewed 296 times.
In Reply To Timing Belt Change...What Upgrades/Maintenance Same Time posted by hcaulfield57 on March 12, 2015 at 10:35 PM
Message So for turning the cams, I recomend a disposable set of pliers and a large close ended wrench.
Turn this around the put the handle end in the holes in the cam, then use a wrench on the other end to turn cams to line up belt.
Also a few small vice grips come in handy for holding the belt in place while aligning other sprockets. I had bad luck with clamps.
Antihero
How to have a good time with your 300zx:
Don't buy from AMS because it's shoddily "designed", cheaply made knockoff garbage.
Don't buy from ASH if you can't wait 6 months for turnaround time, and are ok with him to disapearing for another 6 months when you have a question about your
purchase.
Don't put injectors in that aren't 95+ style Nismo or Injector dynamics
Do your timing belt when you are supposed to with oem stuff.
If a wheel doesn't proudly declare where it's made, you shouldn't be putting it on a 300zx, and if ebay is the best place to get it, that's concerning. Yes, I am talking
about those XXR's.
Don't put on a FMIC that isn't Tom's. That ebay "apollo style" one causes a ton of lag and lost horsepower.
Check my classifieds. My Z is for sale.
