TwinTurbo.NET: Nissan 300ZX forum - The washer will go past the key way.
Subject The washer will go past the key way.
Posted by xpwarrior on March 11, 2015 at 9:09 AM
  This message has been viewed 243 times.
In Reply To Crankshaft Washers Question. posted by bengula on March 10, 2015 at 10:54 PM
Message The notches are in the washers just so they will slide on the crank without having to remove the keys. The washers are sandwiched between the crank, sprocket and pulley and once the crank bolt is tight they will not move around. Just make sure the curved edges of the washers face away from the belt and you should be good.
