TwinTurbo.NET: Nissan 300ZX forum - Re: Crankshaft Washers Question.
Subject Re: Crankshaft Washers Question.
Posted by MaxxAction on March 11, 2015 at 9:07 AM
  This message has been viewed 250 times.
In Reply To Crankshaft Washers Question. posted by bengula on March 10, 2015 at 10:54 PM
Message There are two key ways...
one for the sprocket, and one for the damper. The outside, beveled washer will go past the outer key and set flush against the sprocket. When you tighten the damper, it will pinch the outer washer between the sprocket and the damper.
