TwinTurbo.NET: Nissan 300ZX forum - use this method>
Subject use this method>
Posted by LivinTheDream on March 09, 2015 at 7:56 PM
  This message has been viewed 279 times.
In Reply To Thanks Nate (n/m) posted by FrozTTy on March 09, 2015 at 02:32 PM
Message [ http://www.yugobernie.com/techs/NewStyle_Injector_Install_Guide/ ]
There are two write ups in the link. I found the one at the engine bays relay/fuse box to be the easiest. But you will need to run a acc/switched powered wire to a pin on the ecu in order to retain the self learn and codes.
"torque gets you off the line...& hp gets you over the line." -
TTKeeper
