TwinTurbo.NET: Nissan 300ZX forum - Re: yea I have considered that option but if possible. I'd like
Subject Re: yea I have considered that option but if possible. I'd like
Posted by Goldchocobo on March 08, 2015 at 2:54 PM
  This message has been viewed 275 times.
In Reply To yea I have considered that option but if possible. I'd like posted by nonstopna on March 08, 2015 at 02:41 PM
Message That would be ideal.
Undo your wiring job, and make sure nothing is shorting. Mine had a tiny slit in the hot wire, which shorted out on the shielding.
The best way to test is to check continuity from the ecu to the end of the wiring harness. If it ohms out, you know the issue isn't there.
Here's the circuit diagram for you run into any issues between the ecu and knock sensor.
[ http://home.comcast.net/~tanstrack/300ZX/KnockSensorSchematic2.jpg ]
