TwinTurbo.NET: Nissan 300ZX forum - Code 34 (Knock Sensor) after connector/harness repair.
Subject Code 34 (Knock Sensor) after connector/harness repair.
Posted by nonstopna on March 08, 2015 at 1:16 AM
  This message has been viewed 271 times.
Message To make a long story short I'm getting a code 34 after attempting to repair the engine and knock sensor harness for the knock sensor. The harness had exposed corroded wires from rubbing against another wire or plenum. I figured I'd better fix it now before it starts giving me trouble. I'm also trying to track down an issue with my Z jerking under load. To make things clear I never had code 34 before i started messing with the knock sensor harness. The original connectors were replaced by connectors i got from an infinity J30 because the original ones broke while trying to de-pin. Below shows how I got it set up.... I don't think I have it wired wrong do I? or what am i doing wrong? Also, am I not suppose to get any readings on the knock sensor harness?
