TwinTurbo.NET: Nissan 300ZX forum - Its listed in the 'Engine Assembly' writeup as...
Subject Its listed in the 'Engine Assembly' writeup as...
Posted by -Grimm- on March 03, 2015 at 9:32 AM
  This message has been viewed 362 times.
In Reply To Exhaust Cam Cap Bolt Torque Spec posted by OverZealous (CT) on March 02, 2015 at 09:58 PM
Message "•Replace each cap IN THE SAME POSITION AND ORIENTATION THAT IT WAS REMOVED.Torque the caps to 6.7 - 8.7 ft. lbs.
•Repeat all steps for the 3 remaining cams. (Image 33 shows completed heads) "
HERE
Also, HERE is the proper order.
When I did it, I put a ton of assembly lube on it and tightened to ~20 in-lbs then made sure the camshaft wasn't binding, pushed it forward/backward to seat the caps (they don't move, its just habit), then step up to the torque spec.
1992 300ZX NA 5 Sp (Dead)
1990 300ZX NA Auto 2+2 (Dead)
1990 300ZX TT 5 Sp (Est. 400 HP)
1990 300ZX TT 5 Sp (Est. 600 HP)
2004 G35 Sport 6MT (DD)
