TwinTurbo.NET: Nissan 300ZX forum - Swap the coil packs
Subject Swap the coil packs
Posted by -Grimm- on March 02, 2015 at 5:34 PM
  This message has been viewed 302 times.
In Reply To Re: Try doing a power balance test posted by jhop1988 on March 02, 2015 at 04:54 PM
Message between a neighboring cylinder (cylinder 2 is probably the easiest) and repeat the test.
If the RPM is not affected by cylinder 2 (with cylinder 4's coil pack) then the coil pack is bad.
If the RPM is not affected by cylinder 4 (with cylinder 2's coil pack) then you have to move forward with more testing;
-Check the resistance of the #4 injector
--Bad result (OL or 0 ohms): Injector has failed (replace all 6 with a new style kit from Bernie)
--Good result (10-14 ohms): perform a compression test.
---Compression tests good: Noid light to determine if the injector is receiving proper signal
---Compression tests bad: Leak down test, address issue.
1992 300ZX NA 5 Sp (Dead)
1990 300ZX NA Auto 2+2 (Dead)
1990 300ZX TT 5 Sp (Est. 400 HP)
1990 300ZX TT 5 Sp (Est. 600 HP)
2004 G35 Sport 6MT (DD)
