TwinTurbo.NET: Nissan 300ZX forum - Few suggestions
Subject Few suggestions
Posted by FrozTTy on March 02, 2015 at 9:28 AM
  This message has been viewed 259 times.
In Reply To new engine running real rough posted by jhop1988 on March 01, 2015 at 07:31 PM
Message Run Self Diagnostic first.
Lifter tick will hopefully disappear after you get it running right and you can drive it. Low oil pressure, check your oil pan for dents, as Tanley stated.
Does it have old or new style injectors? If old, I will bet some/all are in need of changing. Ohm test them, should be 10-14 ohms.
High idle - check your IACV, spray some WD-40 in there and see if that helps.
