TwinTurbo.NET: Nissan 300ZX forum - i would recommend using solder joint over a butt connection
SammybTT(TN)
on February 28, 2015 at 9:01 AM
size of knock sensor wire ecu side? (n/m)
posted by msb1987
on February 27, 2015 at 06:25 PM
I am not sure of the wire gauge size. Can you cut off a small section of the un-damaged wire and take it with you when you buy the replacement wire? The vendor should be able to help you find the correct gauge (AWG)
msb1987
18:25:57 02/27/15
Re: size of knock sensor wire ecu side?
ZTom
20:53:19 02/27/15
Thickness, gauge. I need to remove a damaged section and
msb1987
23:40:12 02/27/15
i would recommend using solder joint over a butt connection -
SammybTT(TN)
09:01:33 02/28/15
In the EFI harness?
-Grimm-
09:47:00 02/28/15
I just went through this with my Toyota pickup: UGH!
davidztt
16:43:48 02/28/15
