TwinTurbo.NET: Nissan 300ZX forum - That system is supposed to bleed itself on it's own, so you
Subject That system is supposed to bleed itself on it's own, so you
Posted by davidztt on February 26, 2015 at 1:05 AM
  This message has been viewed 316 times.
In Reply To Seepage from power steering hose. posted by aquariuscsm on February 25, 2015 at 09:06 PM
Message might check to make sure that part of the system is not clogged which could create extra pressure.
Is the end of the pipe perfectly circular? Maybe warped or slightly crimped?
Somebody near you can probably make pipe the appropriate size with flares.
Sometimes a clamp can be too tight. 2nd Stanky; I'm not a big fan of those type clamps, either.
Is it a brand new clamp? Maybe try two clamps. Try a different type of clamp. It looks like there are tiny cracks in the edge of the hose. Is it a factory stock metric hose or an SAE measure inside diameter?
When I had to replace my hoses, it SUCKED! Hope it works out for you.
