TwinTurbo.NET: Nissan 300ZX forum - Re: so its the effect of a bouncing clutch to the trans?
Subject Re: so its the effect of a bouncing clutch to the trans?
Posted by MaxxAction on February 20, 2015 at 9:45 PM
  This message has been viewed 244 times.
In Reply To so its the effect of a bouncing clutch to the trans? posted by Khronik on February 20, 2015 at 09:28 PM
Message When you accelerate, the gears engage. When you decelerate, they disengage. The springs in a clutch hub act much like a shock absorber so that the transition between is much smoother.
As far as your stock clutch, if it is in good shape, and will hold whatever HP you are putting out, it will eliminate the noise.
