TwinTurbo.NET: Nissan 300ZX forum - Re: SZ High 5 Clutch Rattle
Subject Re: SZ High 5 Clutch Rattle
Posted by MaxxAction on February 20, 2015 at 8:44 PM
  This message has been viewed 263 times.
In Reply To SZ High 5 Clutch Rattle posted by Khronik on February 19, 2015 at 06:01 PM
Message The noise you hear is gear lash...
The high 5 clutch is a solid hub. No springs in the hub of the clutch allows the gears to kinda bounce off of each other, or lash. It is especially noisy on my car at idle.
The next time you hear it, press the clutch in, and let it out slowly. The noise should be greatly reduced. Now push the clutch in, then just drop it, and that initiates the lash in the gears, and it will be a lot noisier.
If you want to run a solid hub clutch, expect to put up with the noise. I am getting rid of mine, and going back to a sprung hub clutch, I can't stand the noise.
