TwinTurbo.NET: Nissan 300ZX forum - Re: My guess is the high pressure hose or the seals are worn
Subject Re: My guess is the high pressure hose or the seals are worn
Posted by TyTyIsFly27 on February 20, 2015 at 1:09 PM
  This message has been viewed 199 times.
In Reply To My guess is the high pressure hose or the seals are worn posted by BannonZ on February 18, 2015 at 01:42 PM
Message Thanks everyone. The pump is actually brand new because my old one was leaking last year. My whole power steering system is just in shambles it seems.
Grimm, that is actually where I thought mine was leaking from. Definitely more likely than one of the banjo fittings. I will probably clean everything up, once I pull my motor and once it gets a little warmer here in NY, and try the UV dye idea. Maybe pressurize a few of the high pressure lines to get a working test too.
